Chair carving
  • Thread starter Thread starter Page
  • Replies Replies 16
  • Views Views 2K
Page
Eastern PA
I made a chair the other day out of an oak log. I think when the crane put it in my truck it was about 2000 lbs or so. I probably shaved off 1000 lbs. I can barely lift it with the dingo. I did most of the carving with a stump grinder. A bit with a chainsaw and then some finish work with an angle grinder and shaper disc. 936C8E38-2BCD-4D49-9E95-627B5C77B760.jpeg
Not sure what to do about preserving it. It’s a pretty fresh log and as such was hard to sand the end grain on the seat part. I got everything as smooth as I could for now but it may need more sanding next year. I may wax it.
Maybe wrap it with plastic to seal the moisture in, open it every so often to let a little out at a time?
I would expect some radial cracking across the pith is inevitable. Maybe inlaying some butterflies to help hold the cracks as they may start to form.
Awesome chair!!
Pentacryl will seal/stabilize it. It’s designed for green wood. It’s expensive though. I’ve not used it because I could always dry the wood. The chair would be hard to dry evenly.
Or wax it, let it form some fissures during drying and fill them in 2 years time. 🤷‍♂️
Awesome chair!!
Or simply make a cut vertically through the seat in the back.
That will allow the tangential shrinkage to happen and simply widen the cut, instead of making several cracks.
I don't know that cracks would be bad as long as it doesn't split apart. Cracked wood looks good, but you never know what you'll get til it happens. I guess that could be good or bad. A bit of surprise factor seeing how it ages.
  • #15
I think I’m gonna wax it. I had it covered the other day for a few hours and it already started to mold. If it cracks it cracks. I sort of expected it. If anyone try’s to carve with a stump grinder I would suggest using a very heavy log and burying it partially. Otherwise you’ll suck that log right under and then a variety of bad things happen after that.
