Bridge rope for treemotion
Gypo
Western Oregon
I have searched extensively and not found the info Im looking for.
I have a treemotion that I want to setup with an adjustable bridge. Ive got a ct roll n lock and some new velocity. The problem is that the velocity fit throught the lower d rings is pretty tight so it doesnt adjust very well. It takes two hands.
I was thinking that if there was a 10mm alternative rope that it would feed through the lower dees much better. I would use the treemotion bridge but it isn't long enough.
Velocity will work, just not as good as I would like. Anyone know of a good 10mm bridge material?
Thanks all.
Zane
So, a static rope is the way to go? Never had one, how is the knotability? Need those stopper knots in the end...
Btw Grendel, I enjoy your vidoes very much. We work in simular environments.
Thanks Zane, Levi is right too, Ocean Poly for the win!
I wish I was in your environment man, you guys have the best trees!
Cheers
PS. I've never tried tying the Teufelberger stuff, but the Oceans poly and the KM stuff both knot well enough.
Thanks a bunch fellas. Just ordered some 10mm htp and 10mm ocean.
Some of those big maples you've done in your videos look just like the ones down here. Some of the timber down here is nicer than others, we have some real shit patches at times. Makes you appreciate the good stuff.
