MasterBlaster
Administrator Emeritus
- Thread Starter Thread Starter
- #51
Uhh, me too! :what:
I think you may have come in a bit high on your back cut & either your top or bottom cut on your face may not have been true.
dang Hickory!
But sorry, Butch... me-no-likey. I see safety issues with it. Big time.
High back cut and untrue cuts in the face which left holding wood that I didn't mean to leave...I agree...that was what I deduced, too.
Anytime you're falling stubs that's bound to happen. Especially with a narrow face. Opening it wider can give the work a more room to tip before closing the face, and accordingly more momentum to break the hinge.
Open the face with two 45s and a gap at the hinge and the stub can tip and hit the ground before the face even closes. Often times with the hinge wood still intact.
Again, the tricky thing, or downfall, with falling short sections, stubs, and the like, is getting it to break square off the cut. So many times I've seen these things tip, close the face, stop momentarily, and then cock over to one corner or the other, and end up doing a job on something you worked all day to avoid.
It's the classic, "Last cut, and oops!"
The bottom line is, a stub is more reactive to minor differences in the amount of holding wood in the hinge.
I do that quite often in an attempt to keep the snag attached to the stump.Works real well with pine & hackberry.Open the face with two 45s and a gap at the hinge and the stub can tip and hit the ground before the face even closes. Often times with the hinge wood still intact.
that pic looks like you did the same thing?
I think if I woulda stepped up and pushed it harder, it woulda worked. The trick is keeping that hinge fat. I'll get it next time.
