sierratree
- Joined
- Aug 14, 2011
- Messages
- 171
o.k......what's your reasoning? even if your aim is spot on..........what negatives might you be referring to?
Burnham is a logger.
We don't use taglines.
Unless you'd call an 18 ton dyneema line attached to a skidder a tagline, that is![]()
pull rope with mild tension for direction, that's all.
So you guys are either supporting a weakened/ heavy leaner or just using the rope to commit the tree to the face right?
View attachment 38210View attachment 38211
Sure tag line a heavy back leaner. But when you anchor line a heavy side leaner 90 degree to the lay things get really interesting especially when the side leaning tree always lands to the intended lay.
