woodworkingboy
An older saw but in overall very good shape. The saw starts up fine when cold, but after running a bit then shutting it down and waiting a minute or two, it won't restart without the throttle being pulled at the same time. I cleaned the carb, the diaphragms are in good shape, throttle and choke linkage and idling adjustment is good, the choke lever works as it should, and when it's running, it runs well. The plug spark seems good when it doesn't want to start, first I was thinking that the coil might be going out giving a weak spark. I'm assuming it's a fuel problem in the carb somewhere, maybe I need a new carb? If I wait a half hour or so, it starts normal.
It's got me befuddled. Any thoughts appreciated. Thanks in advance.
