I just didn't want to do the" shoulda coulda woulda " thing later..that's why I got two second generations..the m-tronics are available here now...kinda crazy, but even the dealers here aren't crazy about them...only time will tell..maybe I'll add one later.I didn't like either gen. First was garbage. Second was much better but still was no 200t. I own a020, 3- 200t, and a first gen 201t. I grab a 200 99% of the time. At work we're all second gen 201 now with a single 200 still in use. I still reach for it most of the time. If the new 201tc runs anything like the other m-Tronic saws, it'll be great. My boss has the first two reserved at the local dealer once they come in in January. I'm waiting patiently.
Tough to be an old bird like me...I don't quite understand these brainiac saws...dang.
What do you base that opinion on?
My guess would be that I have quite a few more saw hours/year than you (and in fact most people here) and I find them to be excellent.
I particularly like the fact that you don't have to consider how warm the saw is when starting it, as in " Do I need to engage the choke or not"
Just flip the switch all the way and it'll start, cold or warm.
Fair 'nough.
I'll get back to you in a year.
Actually I have been running the 441 c model for 3 or 4 years now. Does that qualify?
Also, basing your experience solely on Husqvarna is to me like saying you don't like horses because a cow once stepped on your toes.
Talked to my dealer this morning about this.
Try starting it on choke and let it run choked for a minimum of 90 sec.
Turn off
Switch to run, start and let run for a minimum 90 sec without touching the throttle.
Turn off
Restart and make a minimum of 3 cuts at full throttle. More if you have the wood.
If that doesn't set it straight, take it back for the shop to put the reader on.
This did the trick. It felt much stronger today as well.
How often does one have to do this with these 201 mtronic's? Sounds like it can get complicated...
