Al Smith
Mac Daddy
More times than not problems with the 200T are related to bad seals caused by side thrust on the crankshaft bearings .The bearings are roller type with a built in thrust washer within the bearing .
It's relatively easy to change the bearings and seals on this model .The last I did it was around $60 dollars for the parts and a couple of hours to do .I've done a bunch of them .
It was thought at one time these problems were carb related to one model of the Zama C1Q carb where the worn accelerator pump shaft allowed air leaks .I'm not certain if that was actually the problem but a lot of people bought new carbs at 90 bucks a pop from the dealer .
