flushcut
In between sit normal and f,d up beyond all recognition is an important transition phase.
Things are Really f,d up. You have been there, just didn't realize it.
Yep yes I have.
That's an idea. What if I started a thread about my career. That way yall could see and I have a record for myself and of Where I came from. Lol. Would that be acceptable?
I think, once I wake (I'm just now getting ready to leave work to go home), that today I'm going call another local tree service about a job.
On which one Jed? Lol
In going to totally disagree with you Jed about the value of throw weights and lines. I saw a customer recently. Removed a small dead Madrone next to a green house, from the ground partially with a power pole saw because I could set rigging points and set running bowlines on pieces from the ground.I was givin' the thumbs up to both, Popper.
Yeah... You need a real throw bag, but try to stay away from them unless you're only pruning. Spurs, flipline, climb line.... should be all you need to ascend your removal work.
Make a big difference if you have a 35' tree or an 80', or 120' tree.If you're goal is to set a TIP, set a TIP as easily as possible. Does it make more sense to elevate 200#, 80', or 20 ounces of weight and line?
