W
Widow Shooter
Been thinking a lot more about base tie offs.
Usually I but a figure 8 knot on a bight, clip a biner in the loop then back it up with a couple of half hitches and another biner in that loop.
works good, but in an emergency, no way to get lowered out
So I tried rigging this :
Web sling choked around the trunk for smaller trees, the DMM 30kn one, clip a biner in, then rig a figure 8 in there, then do a minimum 3 half hitches on a bight, leaving a loop, clip another biner in there and back to the main biner so the half hitch can't pull out.
it looks like this
I also have a 5/8" eye sling, brand new to use on big trunks, timber hitched backed up by half hitches like this:
This is simple and would allow a person on the ground to lower you, or also, if you lanyard in, would allow more rope to be pulled out if needed
what say you all?
it looks like this
what say you all?
