bonner1040
Nick from Ohio
So Tom Hoffman, Oldfart @ the Buzz, made this thing a while ago called the U-Saver. Its basically a Teufelberger Pulley Saver (TPS) with a steel ring in place of the rope loop at the end. WesSpur released a very similar product, the WesSPur Saver (WSS), ART's Rope Guide (ARG) is really the beginning to all of it I guess.
Toms design improved on the TPS by allowing it to be set up with the rope running through the large ring and the pulley in basket mode, thus being able to be set remotely. This is where I got the idea for my remote rigging thing.
Tom has made a bunch of great videos explaining the entire process from construction to implementation that can be found on his you tube channel
I have never consistently used a Friction Saver and have brought up the topic here quite a few times. The last thing I made, with the knotted rope was half arsed and didnt work well. So a couple of weeks ago I ordered up one of those Pinto Rig Pulleys and some 3 strand. I figured if I still cant get on the friction saver wagon I would be able to use the Rig pulley somewhere else. With work and the issues I was having I hadnt had the time to put it all together.
Since I have a bunch of time lately and already had a bunch of rings and other hardware, I threw one together.
I watched Nick Araya's 3 strand splice video, and was finally able to get the 3 strand eye splices down.
I wont go over everything that Tom discusses in far more detail in his videos, but basically you can set it basket or choked. Basket is with the rope running through the ring and the pulley. Choked is with the pulley through the ring choked on the branch and the climbing line just through the pulley. The snap on the end is a retrieval snap used like with the TPS, WSS, or the ARG. Some of the highlights are:
Anyone use anything similar? Once I am going again I will definitely update on my experiences.
- Can be set and retrieved remotely
- can be choked on a spar and retrieved remotely for working down the stem or choked above a tight crotch.
- adjustable
