Dave Shepard
Square peg, round world.
- Thread Starter Thread Starter
- #26
This thing doesn't seem to want to cold start very well. Don't know if maybe the carb rebuild wasn't very good. Any ideas? Thanks.
It's also good for polishing your metal mirror in the slammer.
The taper on the crank/flywheel is actualy what holds it in place .The keyway is just for reference .
Tooth paste has a very very light abbrasive in it thus gripping the metal surfaces better . Old ,old trick .![]()
Figured out the intermittent not running problem, the fuel tank is not venting. The saw would start and stall, then act like it was flooded, but the plug would be dry. I haven't fixed the vent yet, but found that it will run fine as long as you keep it running. Starts second or third pull.
I also got a new tool for working on saws, a Bosch Impactor. It is an impact driver (), that takes any 1/4" hex bit. I got an assortment of longer torx and hex bits, but I'm going to order some 6" hex bits for taking the saw apart. I found that a lot of the time in working on a saw, especially to the extent of a complete teardown, was spent screwing fine thread hardware in and out. It's got 800 in/lbs, hopefully that and the impact will be enough to get most bolts loose.
Bosch Impactor
I had that problem on two saws .The infamous 2100 Husky and a 2800 Poulan . I stuck vents on them like Stihl uses with the little screw in them [older Stihls ] Problem fixed .Figured out the intermittent not running problem, the fuel tank is not venting. The saw would start and stall, then act like it was flooded, but the plug would be dry. I haven't fixed the vent yet, but found that it will run fine as long as you keep it running. Starts second or third pull.![]()
