mastermind7864
- Thread Starter Thread Starter
- #51
Damn.......that's a bad sign.
It sounds like the 150 was tuned waaaayyyyyyyy too fat though.
stomped.
Welcome to the TreeHouse, brother! Gotta first name? Mine is Butch.![]()
Randy, the MS150 needs more torque, so modify it good.
Here's a video from some arbs over in Europe playing with the MS150 up against Husqvarna's new battery powered T536XP saw.
www.youtube.com/watch?v=eGFNCap2ckg
I don't think a torque build will help out this saw. With that small displacement you are fighting a battle you cant win. What I think it needs is a very un-aggressive chain and a lot of revs to pull it along. Think thin chips and fast chain speed. As soon as you get over aggressive with the rakers you are going to bog.
I think the approach necessary is like a limited displacement car, deep gears and lots of rpm.
Though I know this saw's power can be improved, to me it feels appropriate for the size of the motor. I think there is something else going on around the sprocket. I was burying the bar in some wet Siberian Elm yesterday and when cutting with the bottom of the bar and using the dogs, it would start bogging way to soon but not from lack of power. The chain was clogging and binding. It needed to be pulled across the bark in order to get it spinning again. But like I said earlier, if I used the top of the bar, I could push hard on the cut, even with the bar buried and it cut great, no binding of the chain.
It looks like the chain and bar are cleaning better with the fling off from the bar tip than it can around the sprocket.
David
Thank you for the welcome! My name is Kaz.
David
Wet Siberian Elm will stop damn near any saw out there unless you've got full skip chain on it.....
Ed
Only available at the dealer from what mine said when i picked up the saw.
Coincidently I just got a flyer from Baileys today .They have .043 mini pico on sale 12 inch loop 8.99 ,14 for 9.99.If you aren't set you need to run Stihl chain this stuff cuts better .Fact I have a 12" loop I ran on one of the 200Ts' for a while .I never have any trouble with 1/4 pitch either. This is .043 gauge mini picco.
