Stihl 088 carb problem
Raj
Brantford, Ontario
My 088 was acting up. kicking back when cold. Then it would loose power and die in a cut. It would idle no problem. When reving no load it would sound great, no sputter or hesitation. Spark plug is a nice brown ashy colour with some light black oil around the threads, I do run 40:1 oil.
I put in a carb kit but there was one small brass plug I didn't change and a screw in nozzle that I didn't touch.
Ran good for a few heavy cuts.
Now today it seems to over rev, the speed doesn't match the throttle and when you release the throttle it will drop RPMs to a higher idle, then within seconds rev down to idle. Saw will idle and rev no problem, no cutting.
Whole carb is not available in my area.
Any idea what I missed when i put the carb kit?
Almost sounds like an air leak or split impulse pipe. I presume you have pressure tested the machine?
The 200t carbs used to develop a similar problem - welch plug was often the cause (that and the accelerator pump, which I don't think the 088 has). It may be the issue allowing air in. Simple way is to use something like nail varnish to seal it & then test again.
No pressure test yet.
I did discover the new diaphragm was bent up. Hope that's the issue. Dealer has a new kit coming tomorrow, otherwise I'll try to bend it back.
Does it make a pulsing sound too after you let off the throttle? We have saw like that. I keep forgetting to richen it. It doesn't kick, but can be hard to start and keep going at times as it leans out and dies at idle.
No, just a smooth engine bog. Idles fine and throttles great no load.
Thanks all. Going to make plates for pressure testing tomorrow. Dealer has some replacement parts for me. Hope I solve this. Damn milling is backlogged.
Pressure test. Held 6psi for more than 5 minutes. Pressurized through impulse line.
Metering diaphragm was bent up bad in the carb kit. It didn't push the meter arm down far enough?
Edit. Saw held a vacuum no problem.
Dealer got a whole new kit for me, sold at cost because of the other new kit had the bent diaphragm.
Edit: cylinder compression easily reached 150psi.
  • #10
A Facebook page mentioned that cracks tend to develope in the plastic angle fuel inlet, sucking air. Seems it's not a separate part. Mine has a small crack. What can be done? Rubber extension?
  • #15
I'll put a dap on, wrap some metal around it.
New fuel filter just came in, hope it's all solved. Did a couple passes, one on some white oak and a spruce board for a custy.
  • #16
I have not epoxyed the crack yet. I hate to say I think my fuel filter was a big issue that I over looked. Carb did have some crud in it, and damaged carb kit didn't help, nor the long delivery time for parts. I hope I have it fixed. Milled a 9ft long white oak no problems today, RPMs matched the throttle.
Going to look into a tach to mount on the saw when milling.
I tend to stay away from cheap filters, any good sources for decent aftermarket fuel filters?
  • #18
Now it seems my second 088 has carb problems. Took the carb apart to find little plastic like pieces. Looks like someone used epoxy on a welch plug! Hope to fix it Monday.
  • #19
Some epoxy over the large welch plug?? Carb is easier to tune now, with it removed and cleaned up.
  • #21
Bump.
New issue, my second 088 broke the crank somehow, finally got a new to me one, put the saw back together, new gasket, seals and bearings, cleaned up and lightly oiled (with 2 stroke oil) cylinder, rings and piston. Started up great then died. Now it floods, I was hoping thoughts and prayers will work, so I'll ask for them. Try again tomorrow, both arms and shoulders are sore, the saw has a lot of compression now, for some reason.
If the thoughts and prayers don't work I guess it's going to need the carb taken apart.
I’d just get rid of it ... send it to me and I’ll use it as a boat anchor ... Besides according to @Nutball STIHL is “lacking” in the torque department 😂
  • #25
I did set it to spec, I hope.
Thoughts and prayers didn't work, so carb work tomorrow I guess. Still floods.
I'm thinking of taking and old bar, beefing it up and make a mount to a bench, may be a little easier to pull start and trouble shoot the 088s.
