Welcome to the TreeHouse, Dave!
So what's the problems with driving it? How 'bout those right turns?
Oh, and I'm kinda 0ff, too!
And, yet you seem so normal.
The problems with driving it...there are virtually no similarities to normal motorcycle riding. You don't lean in the turns, you steer (more like an ATV). So you have to retrain your instincts if you are accustomed to 2-wheel motorcycles.
Cornering needs to be relearned. Even though the overall bike is heavy, the side car itself is fairly light without a passenger in it. So the first time you turn right at any speed, the sidecar wheel will come off the ground. It feels like it is going all the way over and will scare the **** out of you. But you will learn how to control that. You can fly the sidecar wheel to get it over bumps on purpose. When your sidecar wheel is in the air it reverts back to a true motorcycle. So you need to "switch" back and forth in your technique. Once you learn the technique the sidecar can be "flown" while you are driving in a straight line. Always a crowd pleaser.
And back to the driveshaft for the sidecar wheel. It is direct drive, there is no limited slip. So it is recommended only to be used on dirt, gravel or slippery conditions. It feels bloody awful on the pavement on a dry day. But like I said, it has it's own separate engagement lever.
Dave
P.S. Butch, thanks for the avatar. I would never have figured out how to do that.
