Hunnicutt
I've got a decent running 200T, but the grounding wire that runs from the ignition coil to the kill switch has faulted. It's the very first saw I ever bought so I've got a little bit of a connection with it. I recently replaced the piston and some other things and now it runs better than when I first got it. Now that the ground wire has broken, I like to joke that the saw runs so good that you can't even shut it off!
Anyways, I'm determined to fix the saw and I bought a new cheapo Chinese ignition coil that came with a new wire. I'm not entirely sure the best way to approach removing and replacing the old wire as it travels through the crank case to get from the ignition coil to the handle. I'm thinking I can remove the flywheel and the handle and pop off the grommets and pull the old wire out without having to really break the saw apart. Is it possible to do this or do I need to split the whole crank case? I can take some pictures if my description doesn't make any sense. Any help of insight is appreciated!
