C
Chisel Tooth
I use a cordless drill on little units like this, the problem I found with the impact is it will loosen the nut on the flywheel. I've also used an electric variable speed drill, these work good as well. Good luck Al most of the smaller saw are a pain to work on no matter what you are doing to them.
