An actual Dremel by brand name is around 85 bucks .Comes with a few bits, case etc . There are cheaper brands which would probabley work . I've got three Dremels myself although I can only find one at the moment which comes as no surprise .
If you get a selection of cutters ,bonded abrasives like Cratex,some felt polishing fobs ,a few stones etc. it doesn't take long to have a couple hundred in the mix .
Now that's a cheap route .You get into to higher end stuff like Dunmore flex shaft grinders and the like you could amass a couple thou in the mix .
On the other end you can actually rework the ports with nothing more than a couple of round files and a bunch of sandpaper although it would take a month of Sundays to get-er-done .Fact is just for giggles I did a clam shell 46 cc Poulan that way just to see if I could .It came out okay for a clam shell .
