Hydro issue ??
  • Replies Replies 15
  • Views Views 1K
flushcut
Delavan, WI
So I’ve been putting the mini back together and have an issue with one of the final drives not going forward only reverse. The other side is fine and normal. Pump is pushing at the pump and to the motor. Any suggestions?
do the motors have a case drain?
might have drain and forward hose mixed up?
me and hydraulics dont get along...
My motors only have two connections. Forward and reverse guessing.
Directional handle tells the fluid which way to go.
I wonder if your valve is pugged on the one side for the directional flow. Hope someone did not leave a plug in it after trying to keep foreign objects out before assembly.
