Al Smith
Mac Daddy
I don't know if it's actually mag or not .Some time ago Mike Acres made some comment about some of the early McCullochs were mag but they had a tendency to crack after extended usage and the process was converted to use an alloy of alumium .
That big Homelite in my avatar is mag and my buddy who welded some spots on the starter housing had quite a time on it .Lawdy I had to make some "ears " which were attached with screws instead of being welded which worked fine but it certainly was a pain in the butt .You know something like that it isn't like you can just trot on down to a dealer and order a new part so you gotta do what you gotta do .
Back to this Husqvarna .If you knew the exact alloy it most likely would simplfy the process of repair but where pray tell that information would be is anyones guess .
