Husky 540ixp review
  • Thread starter Thread starter Mick!
  • Replies Replies 17
  • Views Views 2K
Mick!
South West France
Thought I’d scribble a few thoughts on this saw for those curious about it.
I have had the 536 for a good few years and have like and disliked some aspects of it, the relative lack of power in hard wood like acacia means you have to pick and choose when to use it, lime re-pollards and the like are it’s preferred territory, but it’s by no means first off the shelf on a daily basis.
So the new offering.
It’s got very useable power, a genuine dismantling saw, unlike the 536, and most importantly it has a clutch so you can gauge the pressure needed and back off the power a bit so it doesn’t just stop dead like a battery drill.
It’s heavy, even with the smaller battery it’s heavier than a 201, don’t be fooled by just picking it up in the shop, the addition of the battery adds a lot. One handing at reach is a strain, especially if you’re in your twilight years climbing wise or are not especially strong.
It does promote better saw handling, and you really have to be disciplined about stowing it between cuts on your harness to save energy.
Battery life is good, three will see you through most days, even with a bit of chogging down which is the hardest work a topper will do.
Safety wise the rundown on the chain is in line with other battery saws (it stops ‘quicker’ if that’s makes sense) so it feels less dangerous
The big plus is the lack of noise and that you don’t have to start/stop it, so much so that I went out and bought the rear handled one for ground work, along with the helmet coms it means we can talk about weights, ‘letting it run’ and the minutiae of the work without confusion or shouting.
So, should you buy one? Well it’s expensive, especially with the charger and spare batteries.
In all honesty if you have a decent topper already and are happy with it I wouldn’t lust after it too much at that money.
I am pleased with it however, my go to climbing saw.
Good info, thx.
Though I have no batt saws, I very much like the idea of the quick stopping chain.
What comms did you get?
  • #4
These, the lad bought and fitted them.
Motorcycle ones €300 all in for everything.
How do they work in conjunction with your hearing protection?
Power pack glued on the back, wires through the vents at the back to the earmuffs, he took out the foam and glued the mini speaker things inside and replaced the foam.
You can just see the microphone stem he put in.
Thanks for the pics
Does the hearing pro seem to be as effective now that it was drilled/retrofitted?
  • #8
Thanks for the pics
I hadn’t thought of that.
Couldn’t tell you tbh.
The standard Protos ear defenders are (according to opinions on the forums) not all that effective.
None of my saws are ported mind you.
I don’t feel it’s an issue.
They claim 26dB attenuation. My preferred Husky muffs are -25dB, and I find them perfectly acceptable. For everything I do, I feel they don't let too much noise in. Maybe bigger chippers, or big saws without mufflers would overpower them :shrugs:
I'm an ear plugs and muffs guy unless electric or 193t, then just one or the other.
The speaker wires fill the tiny hole drilled for them.
Comms are so useful when doing more complicated anything, including backing trucks and trailers (here, we have long, narrow, steep, mucky driveways, at times).
Now, If I could get a mumble- fixer app for the comms, it would be great.
I never doubled up on hearing protection, but adding plugs to the Protos when chipping is the common advice.
  • #14
I never did either...until it was too late.
Impossible for you to be certain B, but I don’t think you did a lot of chipping in your career, so to what do you attribute your hearing loss?
Older saws with more exhaust noise? Not wearing EP in the early days?
@Mick! I'll link a post of mine from a thread on the subject. I think it basically covers my answer to your question.
You really know you have it when you can hear your ears ringing in a loud environment
