How to be an excellent groundman
  • Thread starter Thread starter Brandon
  • Replies Replies 35
  • Views Views 11K
You can talk yourself out of making any sort of investment.
What did the guy say ‘if you think you can’t do it, or you think you can, you’re right’
I’d add a few thoughts.
There’s a difference between the way a two man team and a three/four man team operates.
On a two man team the climber has to be much more mindful of the groundies work flow.
Come down and help during the job if possible.
Lower limbs on a rope (even if not strictly necessary) so he can get it in the chipper easier.
The climber can pull the rigging rope himself after a lower to save the groundies time/effort.
I find on a two man crew it usually is a lot more efficient to use a speed line on a lowering job.
Takes around d the same amount of time to set up and the drag can sometimes be halved or more with the assist of gravity, a few slings and an anchor.
Obviously, not every job but you get my meaning, if something below the tree has to be saved from impact then zip it away.
100%.
A climber can easily tension and slack a speed line (foot ascender can be helpful, with or without controlling a lowering line, IME. An elevated bottom-end of speedline termination sometimes helps.
As well, this can be done well while solo work forethought, and possibly more than one speed line.
If I'm solo, I'll sometimes double-whip tackle my Wraptor down a line (using a climb line tail, or dedicated speedline with the climb line or rigging line for lowering).
I more make my rope man or single groundsman haul the rope back up to me.
My thoughts.
He has to manage the rope, if I haul the rope, he then has a tangled pile of shat to sort before the next piece. I'll then rig while he moves the last piece we just took off rope.
Hauling a line back as the climber often has the disadvantage of the rigging being equal or not far above your work postion. Cant really pull much length at a time and hard on the body. Less advantageous. But again, more so about the mess someone will have to sort out. Solved by the ground just flaking the rope.
If I am lowering to one guy, I'll have him catch the piece and then I'll take over. Safer for all involved.
Solo, I can if needed. Retrieve and do again.
Speedline, set the tied off base and work the line into the tree. Tension on a mini porty. Often this is done with a throw line prior to ascent. Line is now already awaiting my arrival to fix onto the porty and redirecct with slings etc.
Plan accourdingly.
