Eric H-L
In another post Stig blew my little beginner mind with this quote:
"You can ALWAYS borecut.
If the tree is small, bore in vertically or 45 degree.
That'll allow boring on trees less than a bar width in diameter. "
I had some curiosity although I am not experienced enough to try anything in a risky situation. When boring in a tree too small, do you slant the bore upward from the hinge or downward? Does it change
in different situations? Do you cut the strap from inside the bore? Or do you pull the saw out and nip it from the back?
