T
TREECYCLE
Was out on a sailboat recently and was checking out the ratcheting Bollards. Had a question for the Grcs owners. If hypothetically you had two GRCS Bollards mounted horizontally on a piece of channel could you double the gearing ratio by feeding a bull line first through one and then on to the next through both? When a not so high lift was needed you would simply use one or use both when tip and butt lowering? Just a thought and as a non owner myself maybe the weight alone would be a pain. thanks
