No_Bivy
- Joined
- Sep 2, 2006
- Messages
- 6,447
He a weird rattle that has gotten worse over the past days......sounded like the locking hub on the driver side....pulled it, no problem there
drove a few days more...noise came and went. Today was a very wet start, so I decided to investigate further.
Pulled the rear drivers side wheels..nothing out of the ordinary. I took it out of gear and spun them...WTF is that!. Pulled the axle to get to the ebrake stuff. 4 broken bolts fell out damn! the other four holding the disc/hub on were hand tight. This truck has disc all around, but the parking bracking shoes are on the inside of the dics hub. No way to tighten unless you pull the axle....great idea engineers at ford had!fock!...Long story short, about three years ago the same thing happened on the other side causing major damage. I caught this one before it grenaded.
This is a 2001 F350 super duty...so if you have the same set up I would pull them to tighten. My guess is they weren't tightened at the factory properly...
I get a pics of the carnage....the good news is the broken shat rollin around in there polished the hell outta everything.
