thattreeguy
Question
I did an emergency job the other day, and had to lift an approx 30" dia log off of a home.
Using only a 5/8 block on a dead eye sling up top, a 3/4 whoopie with a large shackle at the base and a 4x4 ford 350 loaded down with firewood to keep the bed on the ground on the drive way.
Ideally it would have been a crane job, but access sucked and we would have cut down a lot of trees just to get in.
My friends mini ex wouldnt be able support the log on the slope and couldnt let it down if it did fully clear the bldg.
So buckadoo , myself and another fellow set the above mentioned gear and pulled like hell with some great cutting done by myself in the wind, and buckadoo on the ground, we flew that tree off the home.
My question is because it is an insurance job and the 5/8 x 300' stable braid was fiddle string tight, and took the shock load of a 2500lb log, plus the pull from the truck, it is now untrustworthy. It already had a thin spot about 70' in, but its worse now, i wont trust it for zero impact projects anymore.
Would you charge for that gear to be replaced?
Pro rated based on the previous wear?
Its a fraction of what a crane woulda cost.
Anyone have experience with this, any need to show the rope to the ins guys to justify its replacement.
Or just slap it on the bill without blinking?
