lumberjack
Young man on the go
Nope.
Nay.
Hold the pinon steady, both tires off the ground with an open differential. Spine one tire, the other tire spins the opposite direction at an equal speed.
Let you slide just this one time man.That statement was in reference to holding the pinon still, and spinning the tires, not the spin test.
In my mind I was picturing the front axle of the tractor, when I spun a tire one way with the driveshaft locked.
False conceptions!
get a CUMMINS!!! only advantage to the old gm stuff is the non turbos can burn alternate fuels with little modification other than that they suck. Cummins is tried and true.
What does look away meen ?
