Australia tree losses
  • Thread starter Thread starter Bart
  • Replies Replies 6
  • Views Views 5K
Bart
GTA
Anyone find any published information yet? I saw a newsflash about firefighters specifically saving a wild grove of ancient trees from extinction or some such. Perhaps some trees are fire hardy like some PNW trees are. Curious.
They saved the remaining grove of Wollemi Pine, thought to be extinct until it was rediscovered not too many years ago.
The tree losses are immense. It's not just that fire is normal for Australia, its the unprecedented size and ferocity of these fires. Where you may have a 'normal' fire season, the fires may burn a few thousand or hundred thousand hectares...these fires have burned MILLIONS of hectares.
In some areas there are no remaining unburnt areas in proximity for as far as the eye can see, so unless seed has somehow survived the catastrophic heat in some of the fires, regeneration will be a long time coming.
Hving said that however, a friend of mine said she heard a doco of a researcher who has been monitoring an area from the Black Saturday fires, 10 years ago, and where he would have thought there was no comeback, the bush has regenerated...so there is hope.
New Euc trees sprout better after a fire than without from what I've seen here in the States - at least up to some certain temperature and duration of burn. "scarification" (?)
Not the best video on it but what I found and refers to Australia specifically.
Indeed that is the case...but some of the fires were catastrophic, the heat burned eveything but trunks. Just sticks left, not a scaffold branch to be seen..the heat was far beyond the 'normal' seasonal type of bushfire.
I would be very keen to go back to some of the places i worked on my deployment, in like five, ten years time.
