K
KDC
Greetings from the North Carolina piedmont.
I'm looking for help assessing damage that seems to be progressing with an Autumn Blaze Maple. I had 8 of these trees installed in September, 2009 so they've been in the ground at my house for almost three years. All 8 trees were approximately 5-to-6 inches in diameter when installed - I'm not sure how old that makes them.
This summer I have noticed that one of the trees appears decidedly less healthy than the others. The foliage just isn't as full and generally speaking it just looks weak.
I took a closer look at the tree yesterday and I'm seeing damage to the bark that I don't understand. I have attached an image to illustrate what I see. I'm seeing insect activity in the areas where the bark is cracking and revealing the inner wood. There appears to be a couple of different ants - I'm not sure what else is living in there. I don't recall seeing this bark damage last season; my impression is that it is something that is progressing rather quickly.
The only difference in this tree, compared to the other 7, that I would note is that it's bark got damaged by the installers as it was being set into the ground. The third photo from the left shows that area. All of the damaged bark in these photos are on the trunk between the ground and the first branches (about a 5 foot section). There is no noticeable damage above the first branches.
I have also attached a second photo showing a comparison in the canopy of two of the maples. The first is nice and full - the second is the tree in question. The very last photo is obviously right at the base of the tree. Note the larger cracks in the bark. Is there anything I might do to get ahead of what's happening here?
And finally, regarding the pests that are living in the areas with cracked bark: is there a particular pesticide that I might look for?
I would greatly appreciate any ideas you have.
Best regards,
Kevin
Best regards,
Kevin
