flushcut
Do you think that a 54" bar and full comp is to much on a 3120? I know chip clearance will be an issue but it will be used for stumping mostly.
If its for stumping your near rocks so avoid semi or full skip chain. Full comp chain loses alot less cutter length then skip chain when rocked out.Do you think that a 54" bar and full comp is to much on a 3120? I know chip clearance will be an issue but it will be used for stumping mostly.
The quicker sharpening with skip is what I particularly like.
