W
wll
i use ta use bailout but i just discovered a sterling brand, its much like the bailout but is a double carrier kernmantle tecnora construction with a much better feel.
IMO its betta then the bee-line hrc is close but no cigar. I'm mostly on my sp jack but its good to be versatileNever done bail-out here.
thanx mangI thought I had read about this, hear you go WLL:
http://www.gypoclimber.com/showthread.php?t=10447&highlight=bail-out
i have used both but i like the thinner stuff betta. bailout is better then the bee fer sureWhich Beeline did you try? the 8mm is different from the 10mm. (8mm has more tach in the cover, 10mm has more poly)
... Bailout is too stiff for a climbing hitch (Imo), ...
get e'm all, thats what i didI am probably going to order a few different cords now that I have my measurements for the VT. I don't really want to cut up my Bail Out prussic. So I will get some Bail Out, HRC and probably some Bee Line to play with
