Ratchet straps
all mine are either keeper or smart strap brand I think, TSC special when I needed straps, I think 3300 pound WLL and like 16K break strength or something
gonna be honest, even in a tree to hold a codom together, id use chain, ive almost 100% gotten away from straps unless its really tiny stuff, even my 3000 pound mini skid gets a 4 point tiedown with 5/16 or 3/8" chain
I use chains currently but wanna try ratchet straps as a primary and use a chain backup. Chains aren’t easy to get around a large bole aloft, as you know.
its hard to find a good ratchet strap, all mine end up slightly bent and never work right, the strap is easier to get around a pole aloft, ive only ever strapped a tree together twice (in the air) both pine and both under 12" diameter
the one time I did it on the ground I had I think 4 straps around a really rotten pine, way overkill but if im going through the trouble im going to make sure it works!
gonna do what patrick did? or connect the hooks like all us normal guys?
  • #16
I tighten a chain with wedges around a trunk to prevent barber chairs.
Generally, 1 or more 3,333 WLL/ 10K breaking strength to pull a split tree together...easy to tighten as weight is taken off during dismantling.
Yes, chain for barber chair prevention fo sho. I’m digging the wedge trick. Can’t wait to try. Thick side facing ground seems the best orientation.
What WLL ratchet straps do you use? It’s for holding a tree together or reinforcing a co dom. Any particular brand?
This one came up in my memory stuff.
Codom cracked black oak. Lost one binder when she landed. Never did find all of it. The lower one held. Landed right where we needed. FB_IMG_1696031083112.jpg FB_IMG_1696031087264.jpg FB_IMG_1696031093679.jpg
