Raided our old saw stash
  • Thread starter Thread starter D.T.Ruck
  • Replies Replies 8
  • Views Views 2K
D.T.Ruck
CT
Well we shut down for maintenance in February and we're making our way through our garage. I decided to take home some of the saws that I saw sitting around for years that need some good ole loving. Grabbed 5 ms200s a old 015, a husky t540xp, and a echo cs-670. The echo runs. The husky was dropped and some of the wiring in in the handle assembly is causing a short. It ran when held on the ground, if you picked it up it would die out. Some of the 200s run but have some timing issues/ or clutch springs that are shot. Haven't made my way through them all. No idea on the 015, first time I saw it way back in the corner of the shelf hiding in the dark. I'm. It sure how many I will get going or if they will just be parts for another.. I have a lot going on right now between studying for my ornamental/lawn license, making improvements to my recently purchased home and taking care of the kiddos. I'll try to take some photos of the process and will most likely ask some questions from you more experienced guys.
If you consolidated those 200's into at least a couple running ones it would be worth your while.
You really should focus on the 015 and get that running and send me the 200's for proper disposal because they are just a glorified paper weight that everybody loves and covets for some strange reason.
I thought I would just use them for target practice 😜. I'm hoping to get a couple running again.
  • #8
I liked the 201 I modded. But somebody sent that to the ground floor. That will be something to fix afterwards too
