T
Tzed250
Some of you guys may not hit the other site so I thought I would get the info over here.
A while back(a long while actually) I started making plans to mod my MS660. I decided I was going to do it in stages, and try different approaches along the way. The saw had the 0603 Magnum muffler installed before it ever saw wood. Knowing that port work was in the future, and wanting to keep the original cylinder stock to have a backup, I started searching for MS660/066 top ends. I found a set of two cylinders on eBay that had stripped spark plug threads. I took a chance and bought the parts. It turned out great. The bores were in excellent condition and there was no damage. I really liked the deal because one cylinder was a Stihl and the other a Mahle. I had $28.00 in two basically new cylinders. I bought a plug thread repair kit from NAPA for $30.00 IIRC, and I fixed the Stihl cylinder plug threads.
<a href="http://www.flickr.com/photos/41385771@N03/5161655062/" title="insert by zweitakt250, on Flickr"><img src="http://farm2.static.flickr.com/1190/5161655062_45baef7094_b.jpg" width="820"height="655" alt="insert" /></a>
The saw was assembled with the Stihl cylinder and the squish measured. The squish varied across four corners between .021-.025".
The workstand helps.
<a href="http://www.flickr.com/photos/41385771@N03/5161057611/" title="chassis by zweitakt250, on Flickr"><img src="http://farm2.static.flickr.com/1206/5161057611_1c45f56374_b.jpg" width="820"height="544" alt="chassis" /></a>
The first thing I did was clean up the piston. I removed all of the casting flash and then opened the windows for better flow.
<a href="http://www.flickr.com/photos/41385771@N03/5161055573/" title="piston window right by zweitakt250, on Flickr"><img src="http://farm5.static.flickr.com/4062/5161055573_492178040f_b.jpg" width="820"height="655" alt="piston window right" /></a>
<a href="http://www.flickr.com/photos/41385771@N03/5161055065/" title="piston window left by zweitakt250, on Flickr"><img src="http://farm2.static.flickr.com/1315/5161055065_7779fe4a5a_b.jpg" width="820"height="655" alt="piston window left" /></a>
I then started on the cylinder, cleaning up all the ports. I widened the ports to the skirt limits, but I did not change any timing, save for the intake duration which lengthens when you remove the silly lip in the floor. The upper transfers were widened toward the intake side and the port roof cleaned up. The lower transfers were lengthened, along with the cleanup. I prefer not to cut the lowers all the way to the base. The exhaust was widened at the bore, made more square, and the exit size increased.
<a href="http://www.flickr.com/photos/41385771@N03/5161657660/" title="intake 1 by zweitakt250, on Flickr"><img src="http://farm2.static.flickr.com/1405/5161657660_287bcd7a84_b.jpg" width="820"height="655" alt="intake 1" /></a>
<a href="http://www.flickr.com/photos/41385771@N03/5161053235/" title="intake 2 by zweitakt250, on Flickr"><img src="http://farm5.static.flickr.com/4002/5161053235_1bcb48bbca_b.jpg" width="820"height="655" alt="intake 2" /></a>
<a href="http://www.flickr.com/photos/41385771@N03/5161053675/" title="left upper 1 by zweitakt250, on Flickr"><img src="http://farm5.static.flickr.com/4066/5161053675_24bb9d08c0_b.jpg" width="820"height="655" alt="left upper 1" /></a>
<a href="http://www.flickr.com/photos/41385771@N03/5161657316/" title="exhaust 1 by zweitakt250, on Flickr"><img src="http://farm2.static.flickr.com/1384/5161657316_09bbb2caff_b.jpg" width="820"height="655" alt="exhaust 1" /></a>
