NorthWoodsDiver
Perhaps I should have posted on a sailing forum, i don't know. I need a non-locking preferably less expensive version of this: http://www.iscwales.com/Products/Karabiners/KH250-Stainless-Twister-Karabiner/3376/
It's for a lighter duty marine application where I do not desire to have shackles and carabiners to achieve swiveling. It won't be for life support, max load would be a 100-150 pounds I suspect.
For those that are curious, I want to attach this to a device via webbing. Then clip the carabiner to a stainless ring on an anchor line, inflate a lift bag, and have the package slide up the 1" anchor line. Once I ascend the dive I can retrieve the package.
Totally unrelated to trees or climbing but ya'll know your clippy snappy bits so I thought you might know where to find a similar item. I may end up using a bolt snap but doubt the gate opening is big enough.
Thank you.
Edit, Found these but the gate opening is too small http://www.suncorstainless.com/swivel-web-clip It's otherwise the perfect concept. There must be something in between
Thank you.
