L
Levi
Does anyone have an opinion on these either of these saws? I just found a couple for cheap but I have very little experience with Husky saws. Thanks
I'd suggest not to waste you time or money, they are home owner/ranch saws, meant for light to medium duty work. They use the lesser quality parts and are much harder to service than the professional models in that range.
In that size range I'd look for a used 346xp or 550xp, a size up and I'd go with the 362, 357 or 562xp.
brand new?
Thanks. I will heed your advice
Both.. They are interdependent on the echos as I recall. They won't idle well if you dont, and your high end will be weak
If you take out the restriction plate on the exhaust or just cut it to match the exit, retune, you will be very happy with the 355
