FS: 2008 Morbark Blizzard 14
Canuck
Rogue Trader
Al Bird A
250 Hours.
*55" x 33" rigid infeed chute with an 18" wide x 14" high throat opening
*14" Chipping Capacity
*Single (top) horizontal feed wheel measuring 20" wide x 18" diameter with hydraulic
lift assist, manually applied hydraulic down pressure and Automatic Reversing Feed System.
*20" diameter drum with fan air-impeller and two (2) dual-edged chipper knives
*31-gallon lockable fuel tank with and sight gauge
*14-gallon lockable hydraulic oil tank
*Live hydraulics including: ball valve, pump, motor, and V-20 valve
*360-degree manual cranking, height-adjustable, swivel discharge chute with adjustable
flipper end to deflect chips
*2" x 4" tubular frame with 4"square main center beam and telescoping tongue
*6000# electric braking axle with electric break-away actuator
*LT245/75R 16 Radial tires with rims
*License plate holder with light
*Steel battery box
*Bolt-on resin tool box
*Clasp hooks on safety chains
*Registration and operator guide holder
*5000# tongue jack and stationary foot pad
*Bolt-on Aluminum Diamond Plate Fenders
*Sealed heavy duty tail lights
*Engine fully enclosed with fines screen over radiator
*2-1/2" lunet ring with flat 7-pin electrical connector
*Caterpillar Diesel Engine with Pre-Cleaner, 115-HP
*Spare LT 245/75R x 16 Tire and Rim with Spare Tire Mount
*Variable Speed Flow Control
Folding Infeed Tray
2500lbs Hydraulic Winch
$30,000
For the economically challenged among us, how much is that in $US. :)
I wish the infeed on mine folded up like that. Hope you can sell it.
