Plunge and bore I think its the same.
The differance is not in how you insert the bar, it is how the cut is done.
Saving a corner in back is what used to be called "Trigger". Today it is referred to as the "safe way to fell" as you decide when it goes, not tree or gravity.
When I was felling oak, beech lumber, stump jumper was a sure ticket to fiber pull and cracks. A Huge Nono that would give you a trip to pulpwood land again.
Shape of hinge, cutting root legs and corners first before it decide to leave the stump....
A thin hinge hold better than a thick depending on fiber and hight of fell cut. A hinge placed close to center is not as flexible as if it is far out in trunk.
Open face, far out will often hold the tree on the stump. This help you when limbing as the tree stay put and is of the ground a bit.
