Fall color
  • Thread starter Thread starter darkstar
  • Replies Replies 44
  • Views Views 6K
darkstar
Rockclimber/ treeclimber
chattavagas
Here are a few shots around my home.
Im gonna get a tri pod later and try and crisp some up.
Lets see what yall got .
We are having an awesome year, all these photos were taken in low light on cloudy evening.
Best color ive seen in my area in years:P.
I miss the fall colors from back east... I was spoiled in MA and I traveled through CT NY RI VT NH and ME during fall a lot... I used to do antiques when I lived there... Here in CA we get some, but not like back there... Very pretty.:)
fabulous Jer....now try some with the sun backlighting the scenes for a different effect...things really pop
the pastels of yours are awesome
Also, lets see some about 200-400 kb.....
do you have picasa on your puter? It a great quick editor/organizer....and free...
Here's some that I put up a couple weeks ago.
http://www.gypoclimber.com/showthread.php?t=11206
Beautiful scenery Dark. Alas, the leaves have turned and burned here in Mass, going on a couple of weeks now. Now its getting that gray,winter feeling.
Check these out .
Little hike we just did.
The mushroom is fat...
I wanted to capture the crazy lime green ona rock.
Did sepia of water and rock.
And just some leaf.
Roger i need to take a class bad...
Bridge we hiked to i missed the shot
anyhow...:D
Bridge we hiked to , i did poor pics of.
My little healer staying way close to ground on swinging bridge.
Out side my window of home right now.
Maple and dead pine.
PEAK color.....awesome. Is that your private crag in the background?
I went for a walk in the park last weekend, took a few shots. :)
  • #17
More from today
:D
Just blasted a mile down the road to get a couple last pics:P
Tire in river, im getting artsy...:|:
  • #18
Last pic befor dark.
Almost dark in Tennessee River Gorge
cant figure out why you still have color and we dont paul. specially like the squirl
Aren't you at ~2000 feet, willie?
Our fall color is still in, but fading with the rain...and time....
I lightened, saturated, increased contrast, and sharpened your pic, Jer. in www.picasa.com, in about 30 seconds.....It's free, and super easy to use.
You have some nice pics!!
Some quick tips:
Use the rule of thirds......for example, put the horizon or water line at 2/3 or 1/3 height...
Frame main subject loosely following that same rule...but often even off to one side as well as at 1/3 or 2/3 width or height.....
With wide angle photos, put something close in the frame, perhaps partially around the main scene or framing it...often the close object will be out of focus which further helps create depth.
To create less or more depth of field, control the lens opening size, called f/ stops. This is best done by using the camera in aperture priroity mode, or full manual. A small numbered f stop is the largest lens iris opening and gives the least depth of field.
Controlling exposure. If your camera has a spot metering mode, choose it, then set the exposure by aiming on the most important part of the scene. Recompose the image while holding the shutter half way down (which locks the exposure and focus on most cameras) Alternatively, the "evaluative" metering mode generally gives a well exposed image.
  • #23
Rbtree
Roger ,since i was shooting the first set of photos at near dark and very cloudy i am guessing , i was able to really pull out the pastels you commented on . But since i needed tons of exposure the only way to get umm crisper , with the camera only , was to use a tripod etc.
Is this correct ?
And on this photo how can i get the tomatoe sharper while still keeping the background semi sharp?
  • #24
One this pic how could i have better used the camera setting to darken up the rock ?
I know i went alittle overboard on the tree limb in forground, i just coulldnt find anything else to provide depth
