flashover604
Hi all. I've got a client that has several dead and dying ash trees. There are eight in close quarters to each other and one larger one in the center of all of these. (22" diameter vs. 8"-16"). The larger one had half its leaves a couple weeks ago. The others were either leaf-less or had less than half their leaves. What I'd LIKE to do is set a block higher in the central large tree and swing the tops of the other smaller trees to it, which would be away from me on a lift. Do you guys agree with this? I'd take the limbs out of the central tree before rigging to it to avoid and dead branches falling when the limb hits. I'm also concerned about the rigging rope being damaged between the limb or spar section being rigged and the central anchor tree.
Thanks in advance.
Zach
Thanks in advance.
Zach
