Wall of Shame: Wannabe Experts
Such a peaceful, quiet setting, lil wood smoke curling up from the backyard, tree crushes house, no yelling or cursing, just some observing….:/:
you could well be right, Jerry. I thought the thick brush might be an asset with that one. Wonder of the roof was punctured? Kind of in an analytical mood about it with recent happenings. :|:
I don't understand it. I mean, he had the underbed pointing in the right direction! It shoulda gone that way!
Musta been a freak wind orrrrrr something!!!
I remember Burnham and myself agreeing that any logger worth his salt could have felled that one with wedges.
But then we both use hingewood:lol:
I recall that one clearly as well, my old friend. We are doing pretty good, memory still is holding up pretty solid :D.
I was watching the smoke. No gusts at all. Too thin of a hinge is my guess.
That's what I figure...I have cut some before where it looked like a tooth pick was all that broke when the tree went over...it was the rope in the top that started the tree in the right direction for me. I have had some REAL thin hingewood before. :/:
I try not to make it a habit.
Logging eastern hardwoods, you'll get the belt from the guy grading logs in the yard at the mill if you don't have whisker thin hinges. Hence the common borecut.
<div id="fb-root"></div><script>(function(d, s, id) { var js, fjs = d.getElementsByTagName(s)[0]; if (d.getElementById(id)) return; js = d.createElement(s); js.id = id; js.src = "//connect.facebook.net/en_US/all.js#xfbml=1"; fjs.parentNode.insertBefore(js, fjs);}(document, 'script', 'facebook-jssdk'));</script><div class="fb-post" data-href="https://www.facebook.com/video.php?v=10203622353139733" data-width="466"><div class="fb-xfbml-parse-ignore"><a href="https://www.facebook.com/video.php?v=10203622353139733">Post</a> by <a href="https://www.facebook.com/jerry.w.perryman.9">Jerry W Perryman</a>.</div></div>
I've lost bids on removing a tree or limb off roofs, I explain it's going to take a bit more time to secure the tree before I go cutting, it's very likely the tree will upright itself once some weight is taken off or a large limb might go rolling off uncontrolled and do more damage, or worse hurt someone.
