It could be anthracnose, but I don't think so. For starters, I've never seen fungus diseases like that on trees in the dry desert climate of eastern Washington. And in the wetter climates where I do see it, it is usually not perfectly uniform. The damage is usually concentrated in one part of the tree (often the lower branches close to the ground where rain splash can get soil onto the foliage, or on the interior canopy where humidity is highest and air movement the poorest). What I'm seeing is exactly the same pattern of damage on every single plant, regardless of age/size, climate, location, etc. Every single tree has lost all of it's leaves right up to the tips of the tallest branches. The dead leaves have all fallen off and look just the way they would in the fall, with no visible curling/spot deformities like Anthracnose causes.
What is so confusing to me is that defoliation like this is often a sign of not enough water, but we just got done with one of the wettest winters and springs on record for the PNW. Many plants are several weeks behind their normal annual growth cycle due to an exceptionally wet and cool spring.
