K
		klimbinfool
Do you have summer limb drop in your area?
I took some major deadwood out of a 90' Black oak a while back with about a 48"dbh. and did some weight reduction on one large latteral. My eval. to the home owner was this tree is in decline do to the root problems and pockets of decay throughout the tree. He ask if it should be removed I said it could go either way but it will need weight reduction all the way around soon.
I got a call a month later and the 20"dia limb that I did weight reduction on fell off the tree. Ok , I felt bad enough about that and schedualed the tree to be removed this up comming Tues. I get a call Fri. night at 10:pm and another 20" limb fell off the tree. I tell the owner if I wait till Tues. I shouldn't have to climb the damn tree it will be on the ground.Needless to say, with my buggerd up rib, I had to climb today and take off the remaining 20"dia limb over the neighbors house.
You ever have a tree peel aprt like that?
		 He also has a black oak over his driveway that is running the same course. Dead and dying everywhere. I have seen several just split apart this summer in better condition. Don't know what else to do besides removal except coppice/pollarding the tree and see what we get after. Black oaks come back from about nothing left. Construction damage and compaction has killed about half the tree... No tops left.
