Stuck propane fitting in RV water heater
SeanKroll
Olympia, WA
Any tips?
Can parafin wax be used with very light heat?
Any other ideas for a crowded space?
Can’t hurt. Try to concentrate the heat on just the nut and have wrenches at the ready to break it loose before it cools. Looks like aluminum to brass, not a great combination as far as dielectric goes but it is what it is. If it’s the fitting at the Tank be careful of the heat. It’s probably glass lined.
If heat and force don't move it, maybe cut it off and install a new fitting before twisting the tube. I couldn't say exactly how it's done, but I'd guess similar to brake line. Probably need some special tools.
