I'll bore on heavy head leaners. And of course, when bucking.
But for falling every tree? Hogwash, IMO. Slow, too. Can't say it's not.
The GOL guys I've worked around, I get to tapping my foot after awhile. A slight head lean, you can do the traditional backcut and have the tree on the ground quicker than doing the bore cut dance around with your hunched over back exposed to widwomakers. You can't know what the tree is doing if you don't look up.
Only reason I let you get away with calling me slow, is the large body of water between us.
Otherwise I'd love to do a day of cutting with you and see who gets the most logs on the ground.
The "not out of school yet" kid, or the guy who has been a production cutter for most of his life
The reason I borecut is not safety, but because I can't reach through the trees from one side.
That overlong bar that you drag around to be able to cut from one side, is fine for conifers, but try to limb and buck hardwoods with it and you'll be throwing chains all over the place.
One thing you guys don't understand about the GOL, or for that matter every other school of logging, like the Danish forestry school, is that they teach how to do stuff SAFELY!
When you teach a course in falling trees, you have to assume that the students are morons, so you teach the safe way.
I do the same when I start an apprentice up.
Then once said apprentice has a better grasp of the fundamentals, ( aligning cuts, knowing where your bar-tip is at all times and reading lean in trees) I start showing them how to fall trees fast and still be safe.
Personally I use a backstrap on less than one in twenty. Leaners and when falling in hard wind only.
The ones that follow the GOL way completely on every tree are the ones that are unable to adjust their tecnique to fit the situation ( morons!!) that has never been the intention of GOL.
As for the " hunched over back exposed to widowmakers" stuff that is pure bullshit IMO.
Quote: " You can't know what a tree is doing if you don't look up".
If you bore a tree and hold it on a backstrap, there will be no movement in the tree untill you cut the backstrap.
That is when you look up.
