Yes, I did that once.
But I don't know if I'll do it twice, waaay too much time for a blade, boring and tricky to do.
Surely, a quick filling to renew the cutting edge is doable if we take it soon enough, like the chainsaw sharpening. That's only the step 3 in under.
But I waited a long time before filing the suggoï , so it was completely dull. A quick touch could do nothing and I had to cut again the teeth. I use the way to file the big cross cut saws, found on the net.
The suggoï's steel looks like the steel from the saw chain's gouges. hard but workable.
Other brands with hardened teeth are impossible to file.
Here is the process :
- flat filling the teeth's tops to make them level and to remove all the rounded edges (the quickest and easiest part).
- cut the sides of the teeth, and deepen the hollow between them. It's the main part which cancel all interest of the operation, money wise : that takes hours to do.
The special file has a thin rhombus shape and the edge is very fragile. You have to file at 45° from the blade axis. The problem is that the file jams very easily against the acute angle of the next tooth. At this time, a slight lateral movement and the file's edge is very likely to break. You have to push the file down and against the obtuse angle of the first tooth for some strokes, then turn the file 180° to do the acute angle of the next tooth (same hollow) "by the inside", like filling the saw chain's gouges. Do that two times to got the deep needed.
Keep the good form of the teeth, not so easy, and make that the small flat triangular area on the tooth's top (obtained at the first step) almost disappears.
- with a very fine file, make the third cutting edge, the small one at the top, just taking out the rest of the small flat triangular area on the tooth's top.
Note that you have to look at the right angles to file, before the step 1.
- take out the small burrs with a diamond stone, gently passed on the blade's sides, almost nothing at the teeth's tops (it's easy to round them a little and cancel your work).
And now, you got a new saw, almost.
I'll certainly try the quick touch alone, but not the whole process again.
