PTO blew, bearings in my transmission
jalegre0
new jersey, U.S.A
PTO blew all bearings ended up in my transmission put in a new PTO and replace two gears in the transmission cost me $1200 probably saved about $4000 but lost a week
In other news getting married this weekend looking forward to going on the honeymoon
Aaaargh!!! Bad luck man!! But not on the married part! Huge congratulations!
All the best to you guys Jamin!
it could get damaged from forgetting to take pto out, then driving, 10 rpm is the max usually.
If your in reverse then hit something it could get damaged.
If u joints are worn
IN my case who ever put installed previously didnt have correct backlash setting. they had only 4 gaskets between pto and trans. U need a kit that comes with a spacer that is 3/4" and 4 gaskets then your good that the reason my bearing from pto ended up in trans
THANKS GUYS ON THE CONGRATS
THIS MORNING BLEW TWO hydrolic lines then a back tire on Grapple truck. At end of day my trailer tire on bobcat trailer blew. Did a job right after the contractors were there I guess. Looks like they dropped a box of nails in the drive way, seen nails as i walked up the drive to get paid or get back the $700 I just spent on tires and hoses
