Altissimus
...single bed knife held to the drum w 4 large fine thread bolts. Also a plate about the thickness of a heavy duty washer. Since I have owned I have suspected the plate.... Told the guys at Morbarky first year that if I was a machinist I would have to describe the plate's holes as "out of round". If not "wallered out" even....they said no worries just run it. Fast Fwd to now , had a hellish time removing and destroying one of the bolts today. Plate holes are ovalized. Drum is hardened Steel , Bolts are grade 8 ...maybe discard the plate made of soft steel and add hardened steel washers instead.... Good Move ? Or Bad ..
