Here in Tasmania again...
A smallish magnolia, only about 8', apparently was planted about 11 yrs ago.
It started to go back, branches started to die one by one, tip down. It didn't see this stage.
Right now it has one small green branch left, trunk shows green under the bark and has more little epicormic buds starting to show (its still spring here)
The HO cut off the dying branches and leader, only two are left, low down on the trunk completely brown and dead now.
Now, down at the roots it is obvious that the plant was potbound when it was planted, the roots are going round in a circle, probably some girdling going on.
So can root girdling be solely responsible?
Other trees in the area, Robinia, look fine, it was a wet winter...
