dastevoe
Wood Hacker
Well I have finally been reduced to chunkin' up the big blocks with the chainsaw in order to lift them onto the splitter
Got to admit though the 2100cd is the right saw for the job !! Just put it together a short while back ,had to put a new clutch & a bunch of other little odds & ends. The original case I have had the bearing pockets "wallered" out and thanks to a generous fellow in Kaliforny, sent me a good case & some other needed pcs to put it together.
I bypassed the governor on the carb & did a little "massaging" to the internals when it was apart and I have to say the thing is impressive.
It "noodled" through the 30" dia. 24" long "pizz elm" for the OWB like it was nothing. Only came off the 4-stroke blubber when I pushed on her a bit.
I have to admit this saw will not be used a whole lot,probably be relegated to this type of work or maybe milling some day.
Anyone else use the 2100 much ??
Steve
Steve
