My morbark chipper always used to start easy like a car in all but the most extreme cold, turn the key and go. This past summer, like an idiot, I ran it out of fuel. After refueling it just would not start. Tried many things. (Months later I learned the lift pump (brings fuel from tank to engine) was very weak which explains the refusal to restart.) I was desperate to get it started due to huge workload. Finally got a mechanic to come out and look at it. Long story short he said the only way to get it started is using starter fluid. I wasn't good with that but he said it is fine, he does it all the time without problems. Eventually I said ok. It turned over for at least 30 seconds using the starter fluid before it started. That seemed brutal but it ran perfect, as usual, thereafter…..Until cold weather set in this fall. Wouldn't start one cold AM, I called a good mechanic this time, told him the backstory. He said NEVER use starting fluid, it burns up the corner of the top ring causing loss of static compression. He said to use silicone spray, the volatile propellent will get the engine started and the silicone will afford some lubricity. It worked fine and has ever since. At least it brings cold weather cranking to a minimum.
What do y'all think of this, other than NEVER let a diesel run out of fuel, and NEVER let a grubby mechanic near your prized machinery.
